- Click Library, expand the CA ASC VMware VDI folder, select Configuration, go to the Contents section.
- Right-click VSphereDataset and click Check out.
- Right-click VSphereDataset and click Edit.
The VSphereDataset window opens.
- Expand all the folders under VSphere Connection Parameters and double-click the namedConnection folder.
- Enter the name of the connection as specified in the section Configure CA Process Automation VMware vSphere Module.
- Click OK.
- Double-click and verify that the value in each of the following fields in the Parameters folder exists:
- datacenter
Defines the data center the virtual desktop belongs to.
- datastore
Defines the data store that the virtual desktop uses for provisioning.
- resourcePool
Defines the resource pool where the virtual desktop is provisioned.
- hostName
Defines the host name of the VMware server where the virtual desktop is deployed.
- Click OK.
- Expand all the folders in the Host Connection Parameters folder.
- Double-click and complete the following fields:
Note: Ensure that you note the following values in the worksheet for future use.
- hostUserName
Specify the VMware Host Administrator User root.
- hostPassword
Specify the VMware Host Administrator User Password.
- hostUrl
Specify the VMware Host SDK URL.
- Click OK.
- Expand all the folders in the VD Templates folder.
The list of all the templates that are supported to create a custom virtual desktop appears. For example, Windows7Enterprise32Bit, Windows7Enterprise64Bit.
- Type the template name of the vCenter Server that you intend to use.
Note: The template name is case-sensitive.
- Click Save, click Check in, and then click OK.
- Close the data set.
The data set is configured.
