Install and Configure CA Automation Suite for Clouds Powered by Amazon Web Services › Upgrade CA Automation Suite for Clouds with the Service cartridge › Review the Prerequisites
Complete and verify the following items before you start upgrading the CA Automation Suite for Clouds with the solution:
- CA Automation Suite for Clouds Foundation upgrade is complete.
- ASC_Security_GlobalDataset is checked in and closed.
- Open the CA Process Automation client that is configured with CA Automation Suite for Clouds Release 1.5 Service Pack 01.
- Navigate to Default Environment: Orchestrator.
- If AWS_GlobalDataset is checked out and open, check in and close.
If the data set is in the checked out state, upgrade can fail to update the data set in CA Process Automation.
- Ensure that the latest patches are installed on the CA Service Catalog server.
