Previous Topic: Synchronize AWS Master AccountNext Topic: Set up Administrator Account, Map it to AWS Account
Configure the Key Pair File
The Key pair file must be configured in CA Service Catalog to set up the administrator account and map it to AWS Account. The key pair values are used while creating the AWS Master Account and Sub Account.
  1. Log in to CA Service Catalog as an administrator (spadmin).
  2. Click Home, Documents.
  3. Select New Folder, from the Action drop down, and click Go.
    Note: Multiple folders must not be created. Create only one folder and add all key pair files to this folder.
  4. Provide AWS as the Folder Name and a short description in the Description field, and click OK.
    Note: The folder name is case-sensitive and must match the recommendation.
  5. Select the newly created folder, and select Upload Document from Action drop-down and click Go.
    Add New Document window opens.
  6. Browser and select the Key Pair file.
  7. Click OK.
  8. Click Save.
    A message appears confirming successful edit.
  9. (Optional) Repeat Steps 3-8, to add more key pair files.
    The key pair file is configured. You can set up the administrator account and can use the key pair file while creating master account and sub account.
