Previous Topic: Import the Service CartridgeNext Topic: Enable Secured Calls to AWS
Configure CA Process Automation Content
Configure the CA Process Automation content.
  1. Log in to CA Process Automation as a CA Process Automation administrator.
  2. Click Library, AWS Operators folder.
    The AWS Operators content appears.
  3. Double-click AWS_GlobalDataset, click Check out.
  4. Enter information in each of the Value Definitions as illustrated in the following image:
    The graphic shows the folders avaialble in the Value Definition Pane with Login Parameters CHANGE ME highlighted.
  5. Navigate in the Folders tree to the CA ASC AWS folder, select the ASC_AWS_GlobalDataset in the Contents pane.
  6. Edit the ASC_AWS_GlobalDataset.
  7. Click Login Parameters CHANGE ME, edit the fields that are related to the CA Service Catalog administrator.
    User ID
    Specifies the CA Service Catalog administrator user ID.
    Password
    Specifies the CA Service Catalog administrator password.
    Business Unit
    Specifies the CA Service Catalog business unit name. (This value is case-sensitive).
    db_user
    Specifies the management database administrator username.
    db_password
    Specifies the management database administrator password.
  8. Click APP URLs CHANGE ME and edit the fields that are related to CA Service Catalog and CA Process Automation.
    SLCM_URL
    Specifies the CA Service Catalog URL.
    ITPAM_URL
    Specifies the CA Process Automation URL.
    MDB_SERVER
    Specifies the management database server name.
    MDB_PORT
    Specifies the management database port number.
    MDB_DATABASE
    Specifies the management database name.
  9. Click Misc Parameters CHANGE ME, edit the fields.
    Administrator_Email
    Specifies the administrator email id.
    AscUtil_Jar_Location
    Specifies the path of ASCUtil folder where the ASCUtil.jar is located.
    Note: ASCUtil.jar is located in the ASCUtil folder. Copy the ASCUtil folder from the service cartridge bin folder and paste it in the computer on which CA Process Automation is installed.
    TempDir
    Specifies the temporary directory location where the CA Process Automation is installed.
    QuotaThreshhold
    Specifies the value in percentage. When the usage exceeds this limit, an email is sent to the portal administrator.
    QuotaEmail
    Specifies the portal administrator email id.
  10. Click Save and click Check in.
    The CA Process Automation content for the service cartridge is configured.
