Install and Configure CA Automation Suite for Clouds Powered by Amazon Web Services › Import the Service Cartridge
Import the service cartridge (also known as the content pack) in to your CA Automation Suite for Clouds Foundation installation environment in the CA Service Catalog server.
- Open the Command Prompt window, change the directory to %USM_HOME%/filestore/contentpacks/CA ASC Amazon Web Services.
- Run DeployContentpack.cmd.
The service cartridge deployment starts and the following prompt appears:
Please confirm you have already installed the database component
- Type y at the following prompt to continue.
Enter y/n if you have already created Database Objects:
- Type the tenant id at the following prompt:
[input] Enter the id of the tenant you want to import the content pack into (Required):
For example, Forward Inc.
Note: The tenant ID is case-sensitive.
BUILD SUCCESSFUL message appears, on successful deployment. Enter y/n to Create Groups if build is successful.
- Type y to continue:
This script creates the following groups in Active Directory and assigns permissions to the service offerings in CA Service Catalog:
- AWS Manage Master Account=ASCgrp_AWS_ADMIN_USERS
- AWS Manage Sub Account=ASCgrp_AWS_ADMIN_USERS
- AWS Manage VBT=ASCgrp_AWS_ADMIN_USERS
- AWS Manage VBT Access=ASCgrp_AWS_ADMIN_USERS
- AWS Usage Report=ASCgrp_AWS_ADMIN_USERS
- AWS Control VBS=ASCgrp_AWS_USERS
- AWS Create VBS=ASCgrp_AWS_USERS
- AWS Manage Alarm=ASCgrp_AWS_USERS
- AWS Manage EBS Volume=ASCgrp_AWS_USERS
- AWS Manage EIP=ASCgrp_AWS_USERS
- AWS Manage ELB=ASCgrp_AWS_USERS
- AWS Manage Snapshot=ASCgrp_AWS_USERS
- AWS Modify VBS=ASCgrp_AWS_USERS
- AWS User Request=ASCgrp_AWS_USERS
- AWS VBS Access Request=ASCgrp_AWS_USERS
- AWS VBS Access Request Response=ASCgrp_AWS_USERS
The service cartridge is deployed.
Note: Perform more steps on all nodes, for installing cartridges that are configured in a clustered mode. Typically, the installation is performed on a single node and contents like services, forms, events, and reports are reflected on all nodes. However, files like plugin jars, requestshared.xml, must be copied manually to all the other nodes of the cluster.
- Extract cartridge-name.zip to the %USM_HOME%\filestore\content-packs\ and open the cartridge-name folder.
- Open the prescripts folder and run the cartridge-name prescript.bat file as an Administrator.
- Copy the contents of the following folders:
- plugins folder to the %USM_HOME%\filestore\plugins folder.
- images\offerings folder to the %USM_HOME%\filestore\images\offerings folder.
- images\rateplans folder to the %USM_HOME%\filestore\images\rateplans folder.
- Restart the CA Service View service on the Node.
Verify Service Cartridge Post Import
Once you have imported the service cartridge (also known as the content pack), verify that the import was successful.
- Log in to CA Service Catalog as an administrator.
- Select Service Builder, Configuration.
- Click Content Packs.
- Select the content pack that you imported.
- Verify that the following items exist in the service cartridge.
- Offerings (Services)
- Events (actions)
- Report Data Objects
- Forms
- Processes
You verified that the service cartridge has imported successfully.
