You can direct return information to a variable other than the default VOX.voxcommand by specifying the PREFIX operand.
To direct return information to another variable, enter the following command:
PREFIX(newvarname)
Specifies the name of the variable to replace the default.
Note: The PREFIX operand is valid only if the destination of the return information is REXX. For information about specifying other destinations, see the following section.
Copyright © 2011 CA.
