For the following commands, return information is stored in the special variable VOX.voxcommand:
(The voxcommand portion of the stem variable represents the name of the VOX command.)
The VOX.voxcommand.0 variable contains the number of lines of information returned (that is, the number of elements in the VOX.voxcommand variable). The variables VOX.voxcommand.1 through VOX.voxcommand.n each contain a line of information. (The n value represents the last line of return information.)
Note: The VOX.voxcommand variable contains the same value stored in the VOX.voxcommand.1 variable (that is, the first-and sometimes only-return information line).
Copyright © 2011 CA.
