To direct the return information from a VOX command to a specific destination, use the CMDRESP operand :
CMDRESP(destination)
The following are valid values for destination:
Directs return information to a REXX variable. For more information, see the preceding section.
Note: The optional PREFIX operand is valid only if the destination of the return information is REXX.
Directs return information to the external data queue.
Directs return information to the terminal. This form uses the same output mechanism used by the REXX command SAY.
Directs return information to the “bit bucket.” This value discards the return information.
Default: REXX
Copyright © 2011 CA.
