The GETMSGI command fetches the internal pointer to an action message and the actual message text.
"GETMSGI"
Usage Notes:
When you invoke the GETMSGI command, it populates the following REXX variables as shown:
REXX Variable |
Contents After Invoking GETMSGI |
DOMID.0 |
The number of messages in the CA Automation Point action message recall list. This variable contains a value from 0 through 100. |
DOMID.n |
The internal pointer to message number n in the action message recall list. |
DOMID_MSG.n |
The text for action message number n in the action message recall list. |
After invoking the GETMSGI command, you can use the DOM command to delete specific action messages from the CA Automation Point action message recall list.
Example:
Suppose that you want to delete all of the action messages in the CA Automation Point action message recall list every night at midnight. You could set up a time rule to invoke a REXX program like the following one:
"GETMSGI" DO CNT=1 TO DOMID.0 BY 1 INTERPRET 'CUR_DOMID=DOMID.'CNT "DOM DOMID(&CUR_DOMID)" END
Copyright © 2011 CA.
