The GETREXXL command returns a list of active and queued REXX programs invoked from within CA Automation Point. (The GETREXXL command cannot detect REXX programs invoked outside CA Automation Point.)
"GETREXXL"
Usage Notes:
REXX Stem Variable |
Contents After Invoking GETREXXL |
GETREXXL.0 |
The number of active and queued REXX programs invoked from within CA Automation Point (in the default AXC environment). |
GETREXXL.n |
An internal pointer to REXX program number n, indicating the order in which the program was invoked in relation to the others. |
GETREXXL_NAME.n |
The name of REXX program n and its command line arguments. |
Example:
Suppose that you want to stop all instances of a particular program. Your REXX code could look like this:
"GETREXXL" /* GETREXXL populates GETREXXL.0 with the number */ /* of active and queued REXX programs, the */ /* GETREXXL_NAME.i variables with the name and */ /* arguments of a program, and GETREXXL.i with the */ /* number used by STOPREXX to terminate the program*/ DO I = 1 TO GETREXXL.0 parse upper value GETREXXL_NAME.i with rxname. IF rxname = token THEN "STOPREXX "GETREXXL.I END
Copyright © 2011 CA.
