The DELVAR command deletes a status variable from the CA Automation Point variable group.
"DELVAR varname"
varname
Specifies the name of the CA Automation Point variable to be deleted.
Usage Notes:
Example:
To delete the status variable MSG_STATUS from the variable table, issue this command:
"DELVAR MSG_STATUS"
Copyright © 2011 CA.
