Previous Topic: DESTROYMETHOD Command
Next Topic: DESTROYTIME Command
DESTROYPARM Command
The DESTROYPARM command destroys an existing parameter. However, you cannot destroy a method parameter if it has overrides at either the entity level or the time block level. You must first delete all parameter overrides.
ADDRESS VOX "DESTROYPARM KEY(key)
[CASCADE(YES|NO)]"
KEY
Specifies the key of the parameter to be deleted.
CASCADE
(Optional) Valid values are:
YES
Destroy all other items in the database that refer to this item.
NO
Do not destroy any other items in the database that refer to this item.
Default: NO
For example, if you specify CASCADE(YES) when deleting a parameter, all of the personal and time block-specific parameter overrides are deleted. If you specify CASCADE(NO) for a parameter that has personal and time block-specific parameter overrides, the command fails.
Return Information:
After DESTROYPARM executes, it sets the special REXX return code variable RC.
Usage Notes:
For more information about obtaining associated data, see the listparm.rex REXX program.
Example:
The following example removes the entry for the parameter with key 300001030 from the database:
ADDRESS VOX "DestroyParm KEY(300001030)"
