The DESTROYMETHOD command destroys an existing method. However, you cannot destroy a method if it has associated data, such as time blocks, method level parameters, or parameter overrides, at either the entity level or the time block level. Delete the associated data in this order:
Note: For more information, see the descriptions of the DESTROYPARM and DESTROYTIME commands.
ADDRESS VOX "DESTROYMETHOD KEY(key) [CASCADE(YES|NO)]"
Specifies the key of the method to be deleted.
(Optional) Values are:
Destroy all other items in the database that refer to this item.
Do not destroy any other items in the database that refer to this item.
Default: NO
For example, if you specify CASCADE(YES) when deleting a method, all associated parameters and time blocks are deleted. If you specify CASCADE(NO) for a method that has associated parameters and time blocks, the command fails.
Return Information:
After DESTROYMETHOD executes, it sets the special REXX return code variable RC.
Usage Notes:
For more information about obtaining associated data, see the following REXX programs located in the CA Automation Point installation directory \sample\nm:
Example:
The following example removes the entry method with key 200002222 from the database:
ADDRESS VOX "DestroyMethod KEY(200002222)"
