Previous Topic: DESTROYPARM Command
Next Topic: EPWCHECK Command
DESTROYTIME Command
The DESTROYTIME command destroys an existing time block. However, you cannot destroy a time block if it has a parameter override. First you must delete the parameter override at the time block level.
ADDRESS VOX "DESTROYTIME KEY(key) [CASCADE(YES|NO)]"
KEY
Specifies the key of the time entry to be removed.
CASCADE
(Optional) Values are:
YES
Destroy all other items in the database that refer to this item.
NO
Do not destroy any other items in the database that refer to this item.
Default: NO
For example, if you specify CASCADE(YES) when deleting a time block, all of the time block-specific parameter overrides are deleted. If you specify CASCADE(NO) for a time block that has time block- specific parameter overrides, the command fails.
Return Information:
After DESTROYTIME executes, it sets the special REXX return code variable RC.
Usage Notes:
For more information on obtaining associated data, see the listtime.rex REXX program.
Example:
The following example removes the entry for the time with key 400002267 from the database:
ADDRESS VOX "DestroyTime KEY(400002267)"
