Previous Topic: CREATELOGIN Command
Next Topic: CREATEPARM Command
CREATEMETHOD Command
The CREATEMETHOD command creates a new method.
ADDRESS VOX "CREATEMETHOD "NAME(name)
  INVOKE(invocation string)
  USE(TELL|ASK|BOTH)
  [TYP(B|C|D|...|W)]"
NAME
Specifies the name of the entity to be created.
Note: Names can only contain uppercase and lowercase letters, numbers, blanks, and the following special characters: - _ @ # . $ % / ; : \
INVOKE
Specifies the string that is used to invoke this method.
The invocation string must begin with the name of the command or REXX script to be invoked. Parameters that never change can follow. (Parameters can also be added to the invocation by using the PARMS features of this database.)
USE
Specifies what this method is used for. Values are:
TELL
The method may only be used to pass data to the entity.
ASK
The method may only be used to receive data from the entity.
Note: The ASK value on the USE operand is not applicable if you are using the CA Automation Point DBMS.
BOTH
The method may be used to ask, tell, or both.
TYP
(Optional) A one-letter designation that specifies the method type code for the method. When NMFIND is invoked with the MTUP parameter and if the TYP character is a member of the MTUP list, then the method is attempted.
Return Information:
After CREATEMETHOD executes, it sets the special REXX return code variable RC.
Example:
The following example creates an entry in the database for method MyMethod:
ADDRESS VOX "CreateMethod NAME(MyMethod) INVOKE(XREXX1) USE(both)"
