The CREATELOGIN command creates a new login.
ADDRESS VOX "CREATELOGIN USERNAME(name) [ENTITY(key|name)]"
Specifies the name of the login to be created. Usernames can contain uppercase and lowercase letters, numbers, blanks, periods, and the following special characters: - _ @ # $ % \ . :
(Optional) Specifies the entity to which the login is to be associated. If no value is given, the login is created without an associated entity. This can either be a key or a name. Each entity is only allowed one login.
Note: The key or name given cannot be a Notification group.
Default: 0
Return Information:
After the CREATELOGIN command executes, it sets the special REXX return code variable RC.
Usage Notes:
Privileges for a login cannot be set from the REXX interface. Each login created from REXX is assigned the same privileges as the Guest login account.
Example:
The following example creates an entry in the database for login SMIJO21:
ADDRESS VOX "CreateLogin USERNAME(SMIJ021) ENTITY(John Smith) "
