The CREATEPARM command creates a new parameter.
ADDRESS VOX "CREATEPARM NAME(parm name) METHOD(method name or key) ITEM(time key|entity name or key) VALUE(value) [DESC(desc)]"
Specifies the name of the parameter to be created.
Names can only contain uppercase and lowercase letters, numbers, and the following special characters: - _ @ # . $ % / ; : \
Specifies the name or key of the method that owns this parameter.
Specifies the name or key of the entity that owns this parameter or the key of the time block that owns it.
You specify this parameter when you want to create a parameter at the entity or time block level. Do not specify this parameter if you want to create a parameter at the method level.
Note: To create a parameter at the entity or time-block level, you must first create a parameter with the same name at the method level.
Specifies the actual value of this parameter for the specified method and item. This data is passed to the methods. The maximum length of this operand is 240 characters.
(Optional) Describes the use and meaning of this parameter.
When you create a parameter at the method level, you must specify a description of the parameter. When you create a parameter at the entity or time block level, you cannot specify a description of the parameter. This data is not passed to the methods. The maximum length of this operand is 1000 characters.
Usage Notes:
Parameter entries are divided into three increasingly specific classes:
You cannot create (specify) a parameter value at the entity or time block level unless you first create a parameter with the same name at the method level. For instance, if the REXX program that performs the MyPage method has a PagerID parameter and you want to specify the pager ID for Chris, you must issue the following commands:
CreateParm Name(PagerID) Method(MyPage) Value() Desc(Pager ID) CreateParm Name(PagerID) Method(MyPage) Item(Chris) Value(123)
Return Information:
After CREATEPARM executes, it sets the special REXX return code variable RC.
Example:
The following example creates an entry in the database that defines 131 as the value for the parameter WAIT whenever the MyMethod method is used to tell Joe something:
ADDRESS VOX "CreateParm Method(MyMethod) ITEM(Joe) NAME(WAIT) VALUE(131)"
