The following sample REXX code illustrates an outbound notification application:
/* REXX */ ChannelInUse = 'N' /* Channel not obtained yet */ /* Setup Error Handler in the event */ /* program encounters Ctrl-Break */ SIGNAL ON HALT NAME DOEXIT ...
/* Logic to determine which phone number to call */ /* goes here. */ /* REXX variable PhoneNumber is set by user's */ /* application...it is hard-coded for */ /* illustration purposes. */ PhoneNumber = '9,1800-555-1212' Call GetFreeChannel Call MakeOutboundCall PhoneNumber Call UserApplication Call ReleaseTheChannel exit
GetFreeChannel: /*----------------------------------------------*/ /* Obtain an available voice channel */ /* Channel can be obtained by channel number */ /* or by Group, in this example, a Group of ALL */ /* is used...... */ /*----------------------------------------------*/ Address VOX "GETCHANNEL Group(All) Prefix(Handle)" If (rc <> 0) Then Do say 'Unable to obtain an available channel. RC='rc exit 16 End ChannelInUse = 'Y' /* remember we now have a channel */ return
MakeOutboundCall:
Arg OutboundNumber
/* Call number and play preliminary greeting */
/* For improved performance, use VOX CALLPLAY */
/* since VOX message to be played is loaded into */
/* memory prior to making phone call. */
OutboundNumber = STRIP(OutboundNumber)
GreetingToPlay = 'greeting.vox getuserid.vox'
Address VOX "CALLPLAY Channel("Handle") ",
"ToneString("OutboundNumber") ",
"File("GreetingToPlay") FILETYPE(NONINDEX)"
say 'Problem calling number: 'OutboundNumber ' RC='rc
return 16
End
/* Before returning to main line code, you may want to */
/* verify connecting caller, you can use VOX GETDIGITS, */
/* PLAYGETDIGITS and VERIFYUSER commands... */
IdLen = 6 /* Assume Userid is length 6 */
PinLen = 6 /* Assume Pin # is length 6 */
Address VOX "GETDIGITS Channel("Handle") ",
"Count("IdLen") Prefix(CallerId)"
say 'Problem obtaining caller userid RC='rc
return 16
End
/* Get caller's pin number. */
Address VOX "PLAYGETDIGITS Channel("Handle") ",
"FILE(GetPin.Vox) FILETYPE(NONINDEX)",
"Count("PinLen") Prefix(CallerPin)"
say 'Problem obtaining caller pin number RC='rc
return 16
End
/* Verify the connected phone call */
Address VOX "VERIFYUSER Userid("CallerId") Pin("CallerPin")"
say 'Unable to Verify Caller RC='rc
return 16
End
/* Caller is OK, now we can return to main line */
return 0
UserApplication:
/* User specific application can go here */
return
ReleaseTheChannel:
/* Release the channel obtained, this is done */
/* by calling VOX RELEASECHANNEL command */
If (ChannelInUse = 'Y') Then Do
Address VOX "RELEASECHANNEL Channel("Handle")
say 'Unable to release channel RC='rc
End
Else
ChannelInUse = 'N'
End
return
DoExit:
/* Perform any necessary cleanup such as releasing */
/* the channel by calling VOX RELEASECHANNEL command */
/* perform other application specific cleanup */
/* terminate application */
exit
return
