Previous Topic: How You Set Up to Use the Apache Tomcat ServerNext Topic: Install the Notification Website Application on a Non-CA Automation Point Machine
How You Provide Your Own JSP/Servlet Environment
When providing your own JSP/Servlet environment, be sure to leave the Use Local Java Servlet Environment check box unchecked.
The Notification Manager Gateway service requires a compatible version of the Java Runtime Environment (JRE) for the Notification Manager web application to have access to the Notification Manager database. You can also select a previously unused TCP/IP port number for the Notification Manager Gateway service.
After you have enabled the Notification Website, manually deploy the Notification Manager web application into this JSP/Servlet environment. The Notification Manager web application is packaged into a web application archive file (a WAR file) called caapnfy.war. This WAR file resides in the CA Automation Point CLASSES directory (for example, installDir\classes\caapnfy.war). See your JSP/Servlet environment documentation for instructions on how to deploy this application. After both enabling the Notification Website functionality and manually deploying the Notification Manager web application, see the section Optional Configuration Tasks.
Confirm your configuration choices. When the Java/Tomcat Installation dialog, displays it guides you through the process of installing a compatible version of the Java Runtime Environment.
