Previous Topic: Install the Notification Website Application on the Same Machine as the CA Automation Point ServerNext Topic: How You Provide Your Own JSP/Servlet Environment
How You Set Up to Use the Apache Tomcat Server
To use the Apache Tomcat server that is redistributed with CA Automation Point as the web server for the Notification Website.
  1. Check the Use Local Java Servlet Environment check box.
  2. Choose an appropriate context name for the Notification Manager website application and select a previously unused TCP/IP port number for the Notification Manager Gateway service.
  3. Confirm your configuration choices by clicking the OK button. The Java/Tomcat Installation dialog displays. This dialog guides you through the process of installing the Apache Tomcat software and Java Runtime Environment.
    The Notification Website configuration step is complete. Continue with the Optional Configuration Tasks.
