Using Notification Manager › Notification Website Application › Install the Notification Website Application on the Same Machine as the CA Automation Point Server
The Notification Website is included when you choose to install the Server Features from the CA Automation Point installation program.
To enable the Notification Website Application.
From the main window of Configuration Manager, choose Expert Interface, Notification Services, Notification Manager, NM Website.
The NM Website dialog displays.
- Check the Enable Access to Notification Website check box.
- The Notification Website application must run in a JSP/Servlet environment. Therefore provide your own JSP/Servlet environment or install a redistributed version of the Apache Tomcat Server. The required version of the JRE must be installed on your machine.
- The Java/Tomcat Installation dialog displays if either a Java Runtime Environment (JRE) or the Apache Tomcat JSP/Servlet software is needed on your computer.
