Your decision to run the CA Automation Point Desktop as an administrator or as a standard user may vary based on the Windows operating system that you run at your site.
Starting the Automation Point Desktop using AP Autostart Manager or AP Remote Viewer
The user name specified in the "Automation Services Startup Options" dialog and/or the "Remote Viewing" dialog must be a member of the Administrators group.
Starting the Automation Point Desktop as an Application
The CA Automation Desktop is started as an application when you start it from the Windows Start Menu. In this situation, you can run the Automation Point Desktop as either an administrator or a standard user.
Running the Automation Point Desktop as a Standard User
Typically, it is easiest to configure the Automation Point Desktop as a standard user and assign to that user the ‘privileges required for standard users’, which are listed below. Such a configuration works when the Automation Point Desktop is started from the AP Autostart Manager, the AP Remote Viewer, or the Windows Start Menu.
Autostarting the Automation Point Desktop as an Administrator
You can start the Automation Point Desktop from the Windows Start Menu as an administrator with no special configuration. However, if you choose to start the Automation Point Desktop, from the AP Autostart Manager or the AP Remote Viewer as a user who is a member of the Administrators group (but who is not the built-in Administrator), you must re-configure a value in the Windows User Account control (UAC) security settings.
Beginning with Windows Vista, Microsoft has included an enhanced security feature called User Account Control (UAC). A primary function of this UAC component is to prompt the user for acknowledgment when a program elevates into a privileged state. Because the Automation Point Desktop can require one or more advanced privileges, UAC displays an interactive prompt for acknowledgment before allowing execution of the Automation Point Desktop. No interactive prompt displays when you start the Automation Point Desktop using either the AP Autostart Manager or the AP Remote Viewer. Therefore, the prompt goes unanswered and the application appears to hang. The application can then only be stopped using the Windows Task Manager. You can prevent this hang by reconfiguring a value in the Windows UAC security settings.
To reconfigure UAC so that the AP Autostart Manager and the AP Remote Viewer can start the Automation Point Desktop as an administrator
The Local Security Policy dialog displays.
‘User Account Control: Admin Approval Mode for the Built-in Administrator account‘.
The Windows default value for this UAC setting is ‘Disabled’. If that is your current value, no change is required to run the Automation Point Desktop as the built-in Administrator.
‘User Account Control: Run all administrators in Admin Approval Mode‘.
The Windows default value for this UAC setting is ‘Enabled’. This value must be changed to ‘Disabled’ to run the Automation Point Desktop as an administrator other than the built-in Administrator.
Important! Setting this value to ‘Disabled’ reduces the overall security of your system. For this reason, only choose this option if your corporate policy prevents you from running the Automation Point Desktop as a standard user.
Important! This configuration setting will affect all applications.
Regardless of operating system, if your site uses the following features and chooses to run the Automation Point Desktop as a standard user, you must assign the following rights to that standard user:
If you do one of the following:
then the CA Automation Point user must have the following user right:
If you monitor the Windows Security Event log, the CA Automation Point user must have the following rights:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Security
You can assign Read permission to this registry key with the apAddRegRead program.
