Previous Topic: Requirement 2Next Topic: Wizard Interface
Configuration Manager
Configuration Manager is a graphical user interface you can use to configure various CA Automation Point functions and services.
To start Configuration Manager, from the Start menu, choose Programs, CA, CA Automation Point, Configuration Manager.
Configuration Manager is composed of two interfaces:
Note: We recommend that you use the Wizard Interface to perform the initial configuration of essential facilities and services. However, you may want to use the Expert Interface to make smaller modifications. For example, if you have already used the Wizard Interface for initial configuration and only want to modify a specific setting, you may find the Expert Interface more expedient.
The following illustration shows the Configuration Manager expandable tree view with the interfaces and their components:
Configuration Manager Main Panel
The following sections provide a more detailed description of the Configuration Manager interfaces.
