Previous Topic: Configuring CA Automation PointNext Topic: Requirement 1
Component Privileges
When you run any component of CA Automation Point, you do so as a Windows user account. During configuration of CA Automation Point, you can specify user accounts for a number of components that are run automatically.
Each new version of Windows places an increased emphasis on running applications with the minimum possible privileges. By following this commonly recommended security practice, you can reduce your security vulnerability and thus minimize the possibility of a costly security breach.
Those CA Automation Point components that do not require the privileges of a Windows administrator can be run as a standard user. The following table identifies whether a given component can be run by a user who is a member of the Windows Administrators group or by a user with standard user rights. It also identifies any additional privileges that must be assigned to that user to accomplish certain operations.
Component
Run with
administrator rights
Run with
CA Automation Point Installation Program
Yes
No
Configuration Manager
Yes
No
Manage Site Files--Export/Import Utility
Yes
No
All CA AP Windows Services (Notification Server, PPQs, etc.)
Yes
See Requirement 1
No
Automation Point Desktop
Yes
See Requirement 2
Yes
See Requirement 2
VOX Client REXX programs
Yes
Yes
Notification Manager REXX programs
Yes
Yes
PPQ REXX programs
Yes
Yes
Notification Website
Yes
Yes
Web Message Viewer
Yes
Yes
Remote Viewer
Yes
Yes
Speech Notification Client
Yes
Yes
