XCOM Messages › 0854E
0854E
XCOMM0854E SAF SECURITY FAILED
XCOMM0854E SAF SECURITY FAILED, USERID IS BLANK
XCOMM0854E SAF SECURITY FAILED, PERMISSION IS DENIED
XCOMM0854E SAF SECURITY FAILED, RV=xxxxxxxx, RC=xxxxxxxx, REAS=xxxxxxxx
Reason:
SAF security has failed for the action you were performing. This can happen for various reasons, as follows:
- USERID IS BLANK—You have not entered a user ID.
- PERMISSION IS DENIED—Either the user ID or the password (or both) is invalid.
- RV=xxxxxxxx, RC=xxxxxxxx, REAS=xxxxxxxx—These values provide diagnostic information (the return value, return code, and reason code) for the security failure.
Action:
The action you need to take varies, depending on the reason for the failure, as follows:
- USERID IS BLANK—Enter a user ID.
- PERMISSION IS DENIED—Enter a valid user ID and password.
- RV=xxxxxxxx, RC=xxxxxxxx, REAS=xxxxxxxx—Check the return code (RC) in ‘SYS1.MACLIB(BPXYERNO)’ or contact CA Technical Support.
