Reason:
You have issued DISABLE,LIST where list is also specified in an enabled superlist. To disable this list, you must use the FORCE keyword.
DISABLE ALL,FORCE bypasses the check for inclusion in enabled superlists.
Action:
Add the FORCE parameter and reissue the DISABLE LIST command.
