Previous Topic: 0848ENext Topic: 0850E
0849E
LIST XXXXXXXX CANNOT BE DISABLED, XXXXXXXX NEEDS TO BE DISABLED, OR USE ALL/FORCE
Reason:
You have issued a DISABLE LIST command where LIST is the name of an enabled superlist. However, this superlist refers to one or more enabled lists. To disable this superlist you must include the keyword ALL or FORCE, as follows:
Action:
Add the appropriate parameter and reissue the DISABLE LIST command.
