Previous Topic: 0049ENext Topic: 0056I
0053E
WWWWWWWW ABEND XXXX IN MODULE(YYYYYYYY), OFFSET(+ZZZZZZZZ)
Reason:
A task in the CA XCOM Data Transport address space has terminated abnormally. This message identifies the affected task, the abnormal termination code, and the module and location where the termination occurred.
Action:
Obtain the SYSLOG and XCOMLOG, and the system dump (if available), and contact CA Technical Support.
0055E
APF AUTHORIZATION IS REQUIRED TO TRANSFER USS FILES OR USE SECURITY=SAF
Reason:
Security calls to validate access to USS data sets must be made using SAF. Making SAF interface calls in these cases requires APF authorization.
Action:
Make the necessary changes to the processing environment so that the XCOMJOB program will run with APF authorization.
