Reason:
APF authorization is required to run CA XCOM Data Transport functions. The job is unable to continue and is terminated.
Action:
Authorize the CA XCOM Data Transport libraries.
Reason:
The TSO user xxxxxxxx could not be sent a message that a file transfer completed because the CA XCOM Data Transport address space is not authorized (see the chapter “Installing Your Product” in the CA XCOM Data Transport for z/OS Installation Guide).
Note: This situation will not abort the file transfer.
Action:
CA XCOM Data Transport must be authorized if you require this function.
Reason:
All libraries must be APF authorized in order to use the IBM Coupling Facility. The XCOMPLEX requires the IBM Coupling Facility. XCOMPLEX servers will be started but without XCF facility.
Action:
Make sure all libraries are APF authorized.
Reason:
Because the CA XCOM Data Transport address space is not authorized, the CA XCOM Data Transport security interface to the host computer was not available. For this reason, CA XCOM Data Transport ended.
The error occurs running XCOMJOB when LUSECURE=YES is specified in the configuration parameters.
Action:
If you require the use of its security interface, CA XCOM Data Transport must be authorized.
