Previous Topic: Examples of SAF Security Calls—Partner SecurityNext Topic: More Information About Partner Security
Partner LU Security (XCOMEX12)
If LUSECURE=YES and EXIT12=YES, security authorization is handled via Exit 12. The security check by Exit 12 may have one of three outcomes (return codes):
Note: Exit12 does not consult the security package for a decision to grant or deny access.
LUSECURE=YES must be coded for EXIT12=YES to take effect.
If LUSECURE=YES and EXIT12=NO, the user's security authorization is decided by the security package.
If LUSECURE=NO, CA XCOM Data Transport does not check the EXIT12 parameter.
