Previous Topic: How to Use the File Security User ExitNext Topic: SAF Security Call—Partner Security
Partner Security
The Partner LU security is concerned with controlling whether a given user is authorized to perform transfers with a particular partner LU or IP name or address. CA XCOM Data Transport implements the partner LU security through the parameters FACILITY, LUSECURE and EXIT12, which are coded in the Default Options or Configuration member.
If SECURITY=NONE is specified, LUSECURE is not active.
