This parameter indicates the data set type definition, that is specified as LIBRARY or a partner PDS if not specified. If omitted, the site system default is used.
Defines a PDSE
Defines a partitioned data set.
Defines a legacy sequential dataset.
Defines a large format sequential dataset.
Defines an extended format dataset.
Specifies an extended format is preferred. If the extended format is not possible, a basic format is used.
Default: None
