Previous Topic: LDSNTYPENext Topic: LMGMTCLS
LIBNEG
Specifies whether multiple members of a source PDS can be received in a sequential data set on the target.
YES
Specifies that multiple members of a PDS are mapped into a sequential data set on the target.
NO
Specifies that a multi‑member PDS cannot be received in a sequential data set on the target.
Default: YES
Note: The initiating CA XCOM Data Transport system examines the LIBNEG parameter when it determines that the source data set is a library and the target data set is sequential. If LIBNEG=YES, the data from the members of the library is written to a target sequential data set. The target data set does not contain any indication that the original source data set was structured as a library. If LIBNEG=NO, the transfer terminates with an error.
