Specifies the sixteen bits (coded in hexadecimal) of a z/OS message descriptor code.
Value (hexadecimal) |
Descriptor Codes |
Definition |
8000 |
1 |
System failure |
4000 |
2 |
Immediate action required |
2000 |
3 |
Eventual action required |
1000 |
4 |
System status |
0800 |
5 |
Immediate command response |
0400 |
6 |
Job status |
0200 |
7 |
Application program processor |
0100 |
8 |
Out‑of‑line message |
0080 |
9 |
Status display |
0040 |
10 |
Dynamic status display |
0020 |
11 |
Critical eventual action required |
0010 |
12 |
Important information message |
13 |
Reserved for future use |
Default: 0200
Note: The message descriptor codes are selected by the bit configuration, where bit 0 corresponds to descriptor code 1. These codes are assigned to error messages ending with E. The descriptor code is used by CA XCOM Data Transport when issuing WTO macro instructions. z/OS inserts an indicator (a blank space followed by a + sign) at the start of the message.
