Configuration Parameters › CONFIG Member Parameters › ENCRYPT
ENCRYPT
Specifies whether a SYSIN01 file created using the ISPF interface is encrypted.
- YES
Causes a SYSIN01 file created using the ISPF interface to be encrypted in conformance with the Data Encryption Standard (DES).
- NO
Causes a SYSIN01 file created using the ISPF interface not to be encrypted and to conform to the standard EBCDIC character set.
Default: NO
Notes:
- Encryption methods other than the DES are used outside the U.S.
- Because of federal regulations restricting the export of products with cryptographic capabilities, this parameter may not be available or effective in some non‑U.S. CA XCOM Data Transport products.
- If ENCRYPT=YES is specified all batch jobs must use encrypted SYSIN01 files created through the ISPF interface.
