If the STCIP parameter is also specified, STCPORT specifies to XCOMJOB the IP PORT of the started task. That task is the target of the SCHEDULE or INQUIRE.
Specifies a number that indicates the IP port of the started task.
Default: If the STCPORT parameter is not specified, the IPPORT parameter value that is defined in the CA XCOM Data Transport Default Options Table is used.
