Previous Topic: STCPORTNext Topic: SUP_ALLOC_INFO
STCPROTOCOL
Specifies the started task communication protocol that the XCOM jobs use when scheduling requests.
SNA
Specifies that an XCOM job can schedule the request with the started task using SNA communications.
TCP
Specifies that an XCOM job can schedule the request with the started task using TCP/IP communications (non-SSL).
SSL
Specifies that an XCOM job can schedule the request with the started task using Secure Socket Layer (SSL) communications.
PLQ
Specifies that an XCOM job can schedule the request with the started task using IBM Parallel Sysplex Signaling Services. This is referred to as the PLEXQ by CA XCOM Data Transport.
Default: Determined dynamically if STCAPPL, STCIP, STCPLEXQ, or SECURE_SCHEDULE are specified as configuration parameters and not overridden by EXEC parameters. If more than one of these parameters is specified, the value is decided based on the following order:
