Output from the compression utility is handled in accordance with the setting of the CMPRS_SYSOUT_CL server-level parameter. The spool data sets (if they are allocated) will have the following prefixes:
The decimal transfer request number is appended to the prefix to provide a unique spool entry for each compression operation. This naming convention allows for the correlation of compression utility output with a specific file transfer if there is a need for problem determination research after the transfer.
Example:
For a request number 034271, the following spool entry names would apply:
