Configuration Parameters › Destination Parameters for Single LUs, Groups of LUs, and Single IPNAMEs › COMPRESS_PDS
COMPRESS_PDS
COMPRESS_PDS is the parameter that causes the actual PDS compression to happen. If your CA XCOM Data Transport administrator has enabled the programmatic PDS compression feature in a CA XCOM Data Transport region, you can use the COMPRESS_PDS option to control if and when output PDS data sets get compressed as part of the transfer.
- NONE
Suppresses the compression of an output PDS dataset as part of a CA XCOM Data Transport transfer.
- BEFORE
Compresses an output PDS dataset before the transfer of user data begins.
- AFTER
Compresses an output PDS dataset after the transfer of user data has completed.
- BOTH
Compresses an output PDS dataset both before and after the transfer of user data.
Default: NONE
Notes:
- COMPRESS_PDS applies only to PDS data sets that is, or have been, opened for output as the target of a CA XCOM Data Transport transfer.
- If the COMPRESS_PDS option is present in the DEST member for a particular transfer partner, and that DEST member is made available to the XCOMJOB utility that is used to schedule a transfer to that partner, it becomes the default value for all transfers initiated with that partner CA XCOM Data Transport in that invocation of XCOMJOB.
- If your CA XCOM Data Transport administrator configures CMPRS_PDS_ALLOW=YES or CMPRS_PDS_ALLOW=X37, the COMPRESS_PDS=NONE option cannot suppress the compression of an output PDS data set if a z/OS system abend B37, D37, or E37 occurs.
