Previous Topic: Parameters ObjectNext Topic: Group Definitions Object
Working with the Parameters Object
The Parameters object contains all of your settings for each CA Vtape parameter.
You can display the Parameters object to view your CA Vtape parameter settings. You can also perform Refresh actions using this object's Action options.
To display your CA Vtape parameters settings
  1. Open the Object Tree so it is showing the CA Vtape objects as described in the section Using the Windows Client to Access the CA Vtape Objects.
    CA Vtape objects are displayed in the Object Tree.
  2. Click the Parameters object in the Object Tree.
    The table view of the Parameters object appears, as shown in the following sample:
    Screen shot example of the Parameters object.
Note: Click the Help About Object tool bar icon (Screen shot example of the Help About Object Toolbar icon.), to display a description of the field values displayed in the columns in the Parameters object.
Parameters Object Actions Menu
The following Refresh actions are available from the Actions menu option located on the Parameters object view Menu Bar:
Refresh Options
Causes all of the Dynamic Options to be refreshed from the CA Vtape parmlib concatenation.
Refresh Groups
Causes the Groups to be refreshed from the CA Vtape parmlib concatenation.
Refresh Filters
Causes both the Dataclass and Data Set filter sets to be refreshed from the CA Vtape parmlib concatenation.
Refresh Pools
Causes the CA Vtape Volume Pool definitions to be refreshed from the CA Vtape parmlib concatenation.
Refresh Remotes
Causes all of the Peer-to-Peer Remote options to be refreshed from the CA Vtape parmlib concatenation.
