The following sections explain how to use CA Vtape objects to analyze your virtual tape information. The following objects are available:
Displays information about the CA Vtape systems on a single z/OS image.
Displays status about the CA Vtape Groups.
Displays a real time view of the Virtual tape devices being used by CA Vtape.
Displays information about any active CA Vtape Backstore tasks.
Displays information about a MVS defined volume in a CA Vtape system.
Displays information about data sets on the Virtual Volume.
Displays information about the CA Vtape Externalization Queue.
Displays the setting for each CA Vtape parameter.
Displays definition information about CA Vtape Groups.
Displays statistics for each Peer-to-Peer connection between CA Vtape and its defined remotes.
Displays information on each Peer-to-Peer task active in the CA Vtape system.
Displays information on every Virtual Volume Pool defined to the CA Vtape system.
Displays information about the Virtual Volume Free Queue in the CA Vtape system.
Displays the Data Set Filters that direct allocations to CA Vtape Virtual Devices.
Displays the Dataclass Filters that direct allocations to CA Vtape Virtual Devices.
These objects are described in the following sections in the order that they appear in the Object Tree.
