Previous Topic: Externalization Queue ObjectNext Topic: Parameters Object
Working with the Externalization Queue Object
The Externalization Queue object displays all the information about your CA Vtape Externalization Queues.
You can display the Externalization Queue object to view information about your Externalization Queues. You can also perform actions on Externalization Queues using this object's Action options.
To display the Externalization Queue object
  1. Open the Object Tree so it is showing the CA Vtape objects as described in the section Using the Windows Client to Access the CA Vtape Objects.
    CA Vtape objects are displayed in the Object Tree.
  2. Click the Externalization Queue object in the Object Tree.
    The table view of the Externalization Queue object appears, as shown in the following sample:
    Screen shot example of the Externalization Queue object.
Note: Click the Help About Object tool bar icon (Screen shot example of the Help About Object Toolbar icon.), to display a description of the field values displayed in the columns in the Externalization Queue object.
Externalization Queue Object Actions Menu
The Actions menu option located on the Externalization Queue object view Menu Bar provides the following options:
From the Set Backstore menu option, the following sub options are available:
Externalization has the following options:
Start
Begin externalization of the selected group/subgroup combinations.
Stop
Stop externalization of the selected group/subgroup combinations.
Dequeue Virtual Volume has no sub options. When you click this option the selected Virtual Volume is removed from its externalization queue.
