Previous Topic: Group Status ObjectNext Topic: Virtual Device Activity Object
Working with the Group Status Object
The Group Status object contains all the status information about the CA Vtape Groups. The Group Status object is useful for monitoring the status of Groups. You can also perform actions on groups using this object's Action options.
To display Group Status activity
  1. Open the Object Tree so it is showing the CA Vtape objects as described in the section Using the Windows Client to Access the CA Vtape Objects.
    CA Vtape objects are displayed in the Object Tree.
  2. Click the Group Status object in the Object Tree.
    The table view of the Systems object appears, as shown in the following sample:
    Screen shot example of the Group Status object.
Note: Click the Help About Object tool bar icon (Screen shot example of the Help About Object Toolbar icon.), to display a description of the field values displayed in the columns in the Group Status object.
Group Status Object Actions Menu
The Actions menu option located on the Group Status object view Menu Bar provides the following options:
From the Set Backstore option, the following sub options are available:
Externalization has the following options:
Start
Begins externalization of the selected group/subgroup combinations.
Stop
Stops externalization of the selected group/subgroup combinations.
