You can use the actions dialog feature to perform actions on certain objects.
To start the Actions dialog feature
An object in Table View appears in your user-interface window.
The line or lines of object data in the Table View is selected.
The Actions drop down list appears.
The Actions dialog appears.
Note: For more information about how to use the Actions dialog view the Help on Window online help system in the Windows Client or the Navigation online help system in the Web Client. For more information about an object and available object actions view the Help on Object online help system in the Windows Client or the Object-object_name-Help online help system in the Web Client. If the Help on Object for an object or the Object-object_name-Help online help system lists Actions, but the Actions menu option does not display any Actions, it is because your CA GMI license does not authorize you to use them.
