A filter can be built from the fields of the object by combining them into Boolean expressions. You can also use expressions that contain patterns with wildcard characters.
You can refine your filter by using the AND/OR logical operators to combine several expressions. Use parentheses to group sub‑expressions.
You can enter a filter expression directly into the text box at the bottom of the Define Filter dialog or use the typing aids in the dialog. It is possible to edit any expression in the text box.
Observe the following:
