Previous Topic: Virtual Devices Will Not Vary OnlineNext Topic: Virtual Device Appears Hung
Virtual Volume Shortage
If you do not define enough Virtual Volumes for scratch processing, the system issues a SVTnV0424W devn, Pool n, Scratch shortage, Reply R(etry) or C(ancel) message.
Before replying, Retry the new scratch Virtual Volumes, and, assuming a scratch volume range is available in the Tape Management System, add that range to CA Vtape with the following console command:
SVTn ADD VVP=
For more information, see Console Commands.
Run the corresponding Scratch Synchronization job immediately to release as many Virtual Volumes as possible. For more information, see Scratch Tape Synchronization in the Configuration Guide.
