Previous Topic: ERPT0120 and ERPT0130 Virtual Mount Performance AnalysisNext Topic: ERPT0300 Active Virtual Volume Report
ERPT0210 Backstore Volume Retention List
The volume serial numbers shown on this report represent physical volumes that are remounted by the Backstore Engine for the externalization of Virtual Volumes. Volume serial numbers displayed with an asterisk (*) are queued for exclusion by the CA Vtape SET BACKSTORE=EXCLVOL command. Volumes marked with an asterisk are no longer remounted by the Backstore Engine.
Note: The optional sequential file (FILEOUT DD statement) generated in Job EJOB0200, step J0200S02 can be used to exclude the Backstore Engine physical volumes from the ATL/SILO eject process and also used to define the PEXCLUDE file for the CA Vtape Recycle Utility. The file and report generated by EJOB0200 contains information about all the physical volumes the Backstore Engine used up to the time the job was executed. If Recycle has processed some of those volumes, they may be in SCRATCH status.
Example of the ERPT0210 report
05/09/07                                                   CA Vtape r12.0                                                 PAGE     1 16.40.36       ERPT0210                                 All Rights Reserved                                     B A C K S T O R E  V O L U M E  R E T E N T I O N  L I S T                              Detail Listing - Order by System, GRP#, SubGrp, Volume Type (P/D) & VOLSER   (*) Volume queued for exclusion ------------------------------------------------------------------------------------------------------------------------------------   Physical                           SubGrp   Vol     OffSite   Primary    Duplex    Volume   SEQ#  P/D  System  GRP#  S/M/L   Pool#   BackStCpy  Esoteric  Esoteric  Group Description ------------------------------------------------------------------------------------------------------------------------------------   541961       6   P   XE61     41     S     Pool1    None      SL859840            SVT7 GROUP41   540783       4   P   XE61     41     M     Pool1    None      SL859840            SVT7 GROUP41   END OF REPORT 05/09/07                                                   CA Vtape r12.0                                                 PAGE     1 16.40.36       ERPT0210                                 All Rights Reserved                                     B A C K S T O R E  V O L U M E  R E T E N T I O N  L I S T                                                           Summary Listing  VCAT TOTAL - VCAT System ID: XE61               Total P/D Volumes =        2                 Primary Volumes =        2                  Duplex Volumes =        0               Number of VCAT(s) =        1                                 ---------- GRAND TOTAL               Total P/D Volumes =        2                 Primary Volumes =        2                  Duplex Volumes =        0               Number of VCAT(s) =        1                                 ----------
