Previous Topic: ERPT0210 Backstore Volume Retention ListNext Topic: ERPT0300 Active Virtual Volume Optional Output File Record Layout
ERPT0300 Active Virtual Volume Report
The volume serial numbers shown on this report represent Virtual Volumes that currently contain active data. An optional output file can be created. The file creation is triggered by the presence of DD statement FILEOUT. The optional file is provided to allow follow-up processing or additional reporting.
Active Virtual Volumes identified as being in group 0 with a data set name of Volume Unusable - Manual Action Required were selected to be reused by CA Vtape but were rejected as scratch tapes by your tape management system. Identify any action required to recover data if necessary.
The VCAT DD statement is required to resolve subgroup information for the active Virtual Volumes. If you have a single system image, or if your group definitions are identical across all images, a single run of the report will generate accurate subgroup information. If you maintain different group definitions on different system images, you may have to run the report against more than one VCAT to obtain accurate results.
Example reports
/mm/yy                                                          CA Vtape                                               PAGE     1  hh.mm.ss       ERPT0300                      Copyright(c) yyyy CA. All Rights Reserved                                          A C T I V E  V I R T U A L  V O L U M E  R E P O R T  -----------------------------------------------------------------------------------------------------------------------------------         Sub Last Reference System   Volume Cache  Extrn 1st Dataset Name                                 Tape     Cmp Last Modified     Grp Grp      Date        ID     Serial  Y/N    Y/N                                                   Sz/MB     %      Date  ----------------------------------------------------------------------------------------------------------------------------------- 0    0          2003/05/21 CA71     100058 N      Y     Volume Unusable - Manual Action Required            8    0.00    2003/05/21      0          2003/05/21 CA71     100066 N      Y     Volume Unusable - Manual Action Required            8    0.00    2003/05/21      0          2003/05/21 CA71     100067 N      Y     Volume Unusable - Manual Action Required            8    0.00    2003/05/21      0          2003/05/21 CA71     100361 N      Y     Volume Unusable - Manual Action Required            8    0.00    2003/05/21      0          2003/05/21 CA71     100362 N      Y     Volume Unusable - Manual Action Required            8    0.00    2003/05/21      0          2003/05/21 CA71     100363 N      Y     Volume Unusable - Manual Action Required            8    0.00    2003/05/21      0          2003/05/21 CA71     100364 N      Y     Volume Unusable - Manual Action Required            8    0.00    2003/05/21      0          2003/05/21 CA71     100365 N      Y     Volume Unusable - Manual Action Required            8    0.00    2003/05/21      0                                          8        64    0.00      0                                          8        64    0.00      1  S       2003/05/08 XE61     100041 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2003/05/08 XE61     100044 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2003/05/08 XE61     100048 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100012 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100013 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100014 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100015 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100016 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100022 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100029 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100033 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100036 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100037 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100051 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/23 XE61     100052 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         400    0.00    2002/12/23      1  S       2002/12/19 XE61     100525 N      Y     ZOBKU01.SVTS01.DSSBKUP.B2                         268    0.00    2002/12/19
     .      .      .      .  GRAND TOTAL                                      6,189                                                          1,790,028   35.70  dd/mm/yy                                                          CA Vtape                                               PAGE     1  hh.mm.ss       ERPT0300                         Copyright(c) yyyy CA. All Rights Reserved  dd/mm/yy                               A C T I V E  V I R T U A L  V O L U M E  R E P O R T                              Page     1                                                             Report Summary 0GRAND TOTAL   Active Volumes =    6,189     In Cache =      106 Externalized =    6,188                Total Tape Storage(MB) =   1,790,028    Avg Cmp % =  3.97
