Previous Topic: Using CA Earl with CA VtapeNext Topic: CA Vtape Supplied CA Earl Reports
Sample CA Earl Components
The following list shows the supplied members that are used to produce the various CA Earl reports.
Note: If you intend to modify an existing sample, copy the sample into a new member and modify that new member, because subsequent product maintenance could overlay your changes.
The following is a list of the provided sample CA Earl components and their supplied members:
CA Earl component: Procedures
Member: EREPORT
JCL procedure used to run CA Earl reports. This procedure requires customization.
CA Earl component: CA Earl File Definitions and Record Layouts
Member: EFMTGRP
CA Earl copybook member that provides data and file definitions for accessing the CA Vtape Group (GRP) and Sub-Group (SGRP) records.
Member: EFMTLOG
CA Earl copybook member that provides data and file definitions for accessing the CA Vtape Group log records.
Member: EFMTVVE
CA Earl copybook member that provides data and file definitions for accessing the CA Vtape Virtual Volume Entry (VVE) records.
CA Earl component: Copy Books
Member: ERPTOPT
CA Earl copybook member that defines CA Earl execution options.
Member: ERPTHDR
Standard heading line format for CA Vtape.
CA Earl component: JCL Members Required to Produce CA Earl Reports
Member: EJOB0110
Execution JCL to invoke IDCAMS. Issues delete and define statements for generation data set used by EJOB0120 and EJOB0130.
Member: EJOB0120
Execution JCL to invoke CA Earl to produce Report ERPT0120.
Member: EJOB0130
Execution JCL to invoke CA Earl to produce Report ERPT0130.
Member: EJOB0200
Execution JCL to invoke CA Earl to produce Report ERPT0200.
Member: EJOB0300
Execution JCL to invoke CA Earl to produce reports ERPT0300 and ERPT0301.
CA Earl component: CA Earl Report Programs
Member: ERPT0120
CA Earl program that creates a daily Virtual Mount Performance Analysis Report.
Member: ERPT0130
CA Earl program that creates a monthly Virtual Mount Performance Analysis Report.
Member: ERPT0200
CA Earl program reads the Local VCAT and extracts group information. The extract file is input to ERPT0210, the Backstore Volume Retention Candidate List Report.
Member: ERPT0210
CA Earl program that creates the Backstore Volume Retention Candidate List Report. The report details the physical volumes in use by the Backstore Engine.
Member: ERPT0300
CA Earl program that creates the Active Virtual Volume Report. The report details the Virtual Volumes currently in use.
Member: ERPT0301
CA Earl program that creates the Scratch Summary Report. The report summarizes a count of Virtual Volumes in scratch status.
