Previous Topic: REPORT=BACKSTORENext Topic: Sample CA Earl Components
Using CA Earl with CA Vtape
CA Earl provides you with the capability to design and produce customized reports. Easy access to system information provides flexibility and lets you tailor reports to your desired format.
You can modify or use the samples provided to report or extract information unique to the system. These jobs are distributed in the HLQ.CCUUECPB data set. A cross reference of supplied CA Earl members can be found in the E$INDEX member of the HLQ.CCUUJCL data set.
Note: For additional information about CA Earl, see the CA Earl Reference Guide.
